You can use AI hosting controls to restrict AI model requests to Figma’s Amazon Web Services (AWS) environment.
Note: Figma for Government automatically routes all AI hosting and traffic through AWS. This restriction is built in and does not require the Governance+ add-on or configuration through AI hosting controls.
How AI hosting controls work
AI hosting controls let organization admins choose how AI traffic is routed.
When enabled:
- For all features governed by the AI toggle, when the feature needs to leverage an AI model, we route the request to a multi-tenant Amazon Web Services account that Figma owns
- We then process the request on Amazon Web Services (AWS) using models hosted in Figma's AWS environment, including Amazon Bedrock and Amazon SageMaker. AI data won't be sent to non-AWS providers. This means AI data won't be sent to APIs outside of Figma’s AWS environment e.g. OpenAI, Anthropic, or Google Cloud Platform etc.
Be aware that when traffic is restricted, output quality may vary and some AI features will not be available. The list of unavailable AI features may change over time:
- The Google Drive MCP connector
- Remove Object
- Separate Layers
- Boost Resolution
- Edit Image
- Expand Image
- Vectorize
Restrict AI traffic
AI must be enabled at the plan level or in at least one workspace before you can turn on the restriction.
- Open the file browser.
- Click Admin in the left sidebar.
- Select Settings.
- Click AI controls in the AI section.
- Turn on Restrict AI traffic to Figma’s AWS environment in the AI features modal.
If AI is disabled across the plan and all workspaces, you can’t turn on this restriction.
