Who can use this feature
Government and Enterprise plans with the Governance+ add-on
Organization admins only
Admins can connect more than one identity provider (IdP) to their organization. This allows you to:
- Support multiple authentication methods across different business units or regions
- Run parallel IdPs during migration or consolidation projects
- Offer flexibility for hybrid IT environments
Figma routes users to the correct IdP based on their email domain. Each domain maps to exactly one IdP at a time, and a single IdP can serve multiple domains.
Set up multiple idPs
For provider-specific configuration details, see the Guide to SAML SSO.
- Open the file browser.
- Select Admin in the sidebar.
- Select the Settings tab.
- Select Manage identity providers (IdP) under Login and provisioning.
- Click + Add IDP.
- In the modal, select Edit configuration to update the identify provider and SAML Single Sign On (SSO) configuration details.
- Choose your provider type.
- Provide IdP details (such as metadata URL, entity ID, or signing certificate). For more information on setting up identify providers, see Guide to SAML SSO.
- Select one or more domains whose members should authenticate with this IdP.
- Test sign-in using an email on a mapped domain to confirm it’s working correctly.
- Repeat for additional IdPs as needed.
The Identity providers table will show each IdP and its mapped domains.
- Select an identify provider from the table to edit IdP details or domain mappings.
- To remove an IdP, hover over an IdP on the table and select More > Remove. Be sure to remap domains first (either all to one IdP or to different IdPs) to prevent login disruption.
- Users on unmapped domains won’t be able to sign in with SSO.
- Figma Enterprise: If your organization allows any login method, those users can still sign in with other methods.
- Figma for Government: Invited users can sign in with a magic link.
