Before you start
Who can use this feature
Standalone Figma Design AI tools are available on paid plans. The Figma agent and supported features accessed through it are available on all plans.
Standalone AI tools require a Full seat. To ask the Figma agent to make edits, you need a Full seat and edit access to the file.
AI outputs may be misleading or wrong. The information provided by the tools should be regarded as a general reference and not a fact or a substitute for expert advice or your own research.
Learn more about accuracy and responsibilities when using Figma AI.
Figma AI helps you get started faster, find what you're looking for, and stay in the flow. In this article, you can explore all the AI features available in Figma Design.
You can access Figma AI tools using Actions in the Figma Design toolbar. If an admin has disabled Figma AI for your team or organization, you won't be able to use these features.
Beginning May 20, 2026, Figma’s agent—a new way to use AI in Figma Design—is rolling out in beta to eligible users. Learn more about the agent in Figma Design.
Note: Figma AI uses a credit system that is shared across all Figma AI features and products, including some tools mentioned in this article. Learn more about how AI credits work.
AI tools in Figma Design
Find assets and designs
Figma AI can help you track down designs from across your team, organization or within Figma Community files.
Start a search using part of a design, a screenshot, or just a description.
Replace content
Replace placeholder or duplicate text with unique, realistic content.
Add interactions
Quickly turn your designs into an interactive prototype.
Rename layers
Organize your file by giving all your layers meaningful names with a click.
Rewrite, translate, and shorten text
Rewrite text to give it a different tone, translate it to another language, or shorten it to fit your designs.
Make and edit images
Generate and edit unique images using a written prompt.
Remove background
Remove an image's background to isolate the main subject.
Boost resolution
Improve sharpness and clarity of low-resolution images.
Expand images
Extend images in Figma Design beyond their original borders using AI.
Isolate and erase objects
Use Select area to define an object or area to be isolated as a new image layer or erased from the image.
Vectorize images
Use Vectorize to convert raster images into editable vector layers.
First Draft
First Draft with Figma AI lets you transform an idea into editable designs in a couple of minutes.
This helps you explore a wider range of design possibilities and iterations quickly, and reduces the amount of effort needed to manually create early explorations from scratch.
Beginning May 20, 2026, Figma’s agent will be the new entry point for First Draft functionality, offering a more powerful way to explore, iterate, and refine your designs. The agent is currently in beta and rolling out gradually. Learn more about the beta rollout.
Troubleshooting
Something not working as expected? Check out our guide to Troubleshooting AI tools.
AI considerations and best practices
When it comes to building AI, we want to be transparent about what we're doing and what this means for you. Learn more about Figma's approach to AI.
There are a few things to keep in mind when using any AI tool:
Accuracy
AI-powered tools are designed to provide information and results based on artificial intelligence algorithms and identify patterns and relationships from large amounts of data. It's important to note that the accuracy and reliability of these results may vary.
There is a possibility of inaccuracies, omissions, or misleading outcomes due to the complexities and limitations of AI technologies. Therefore, the information provided by the tool should be regarded as a general reference and not a fact or a substitute for expert advice or your own research.
Your responsibilities
- You should exercise your own judgment and discretion when using AI-powered tools. It's essential to verify and cross-check the information provided by the tool before making any decisions, taking actions, or relying on it for critical matters.
- You should let others know when you're using or presenting AI-generated outputs. For some features, like summarize stickies, Figma will indicate when an output is AI-generated.
- You will only use AI features in accordance with Figma's Acceptable Use Policy.
