Before you start
Who can use this feature
Figma Make is available for Full seats on paid plans.
You can try Figma Make on other seats and plans.
What is Figma Make?
Figma Make is an AI-driven, prompt-to-app tool that lets you bring ideas and existing Figma designs to life as interactive apps. Through conversation, you can ideate, iterate, and improve your apps.
Use Figma Make to:
- Preview the look and feel of your designs in a functional form
- Turn proposals and ideas into prototypes to help hone your product approach
- Explore a variety of solutions for a problem you're trying to solve
Figma Make provides several features that make it easy to transform your Figma designs into interactive apps:
- Attach your existing Figma designs, components, Community content, and other files to your prompts
- Edit your app using the Figma Design-style properties panel, draw tool, annotations, and conversation
- Search the web for current information or fetch content from a specific URL to ground your app in real-world data
- Collaborate with your team in the same conversations, leave comments, and simultaneously modify the generated code
- Share previews of your app with teammates
- Publish your interactive app as a website with a dedicated URL for your organization or live for anyone on the web
To get started, check out Create a Figma Make file. You can create Figma Make files the same way you create other new files in Figma. In the file browser, navigate to your drafts. Then, in the upper-right corner, click Make.
Note: Figma Make may incorporate third-party content from the internet—such as fonts, code packages, or images—into your app. You are responsible for ensuring you have appropriate rights to all content before publishing.
Find your way around
Figma Make offers a straightforward interface to help you start generating prototypes from your designs as quickly as possible. Figma Make has two primary areas: the AI chat, where you can prompt the model, and the preview, where you can interact with and modify a working version of your app and edit the code.
Chat with agent
The chat in Figma Make is where you'll share Figma designs and images, converse with the agent to generate your interactive app, and iterate by prompting.
Bring your design, images, and other files to Figma Make
To use your existing designs to generate an app, click +, then Add context. Paste the URL to the design you want to use. You can attach more than one design to help give the model more guidance. In the same interface, you can drag or paste images, text files, and more.
You can also paste frames and components from your designs directly into the chat.
Guide the agent with conversation
Have inspired ideas or instructions you want the model to follow? Just chat with the agent and work iteratively with Figma Make to bring those ideas to life.
Run multiple prompts at once
You can run more than one chat at the same time in a single Make file, so you can start a new change while another chat is still working. You don't have to wait for one response to finish before moving on to the next thing you want to do.
Iterate with Figma Make's editing tools
Improving your interactive app is as simple as continuing to converse with the agent. You can also:
- Use the edit tool to point to specific parts of the preview in Make and make adjustments with a Figma Design-style properties panel
- Use the draw tool to mark up the preview and add those areas to your prompts
- Add annotations to your Make preview to give the agent instructions for specific elements
- Use the version history to edit earlier versions of your app
- Attaching designs, images, and other files to your prompts
Create an interactive app
Ready to get started? Check out Create a Figma Make file, where you'll find all the details to help get you started generating with the AI chat.
Once you have your interactive app, you can also view it in a dedicated, fullscreen preview, similar to Figma Design prototypes.
You can also add a backend to your app to securely store and manage data. For example, you’ll need a backend when you want to maintain the state of an app across different browsers, provide login screens, save and load content like text and images, and store secrets and API keys.
Collaborate on and share your apps
After you've created an interactive app, you can share it in different ways with your teammates or anyone on the web.
Copy a Figma Make preview as design layers
In Figma Make, you can can copy a snapshot of a preview as layers and then paste those layers into Figma Design. Bringing in Figma Make previews as layers is a great way to iterate on designs with other teammates. For example, you could copy the different interfaces in your web app one at a time, and then use a Figma Design file as a place to collaborate with others, try out different design ideas, and further edit the designs.
Create and use templates
Templates in Figma Make are a great way to create a high quality foundation for users in a team or organization to get started faster with Figma Make.
Templates enable you to:
- Build a polished Figma Make file that's consistent with brand and product guidelines
- Share that file with others to use while setting guidelines for how the styles and functionality can be changed
- Let members of your team and organization get making in a way that respects the guidelines you’ve set
When you create a template in Figma Make, your teammates can start using the template right away to riff on and experiment with the work you've been doing.
Create and publish a Make kit
In a Make kit, you can add npm packages to provide context on which assets—like components, styles, and tokens—to use, import variables and styles from your design library, and write guidelines to provide context on how the assets should use style context and behave.
Share and publish
You can share a preview of your interactive app with anyone you want, using the granular permissions to control access and keep your concepts safe.
Then, when you're ready, publish your interactive app for your organization or to public web with its own dedicated URL courtesy of Figma. You can also assign a custom domain that you own.
What's next?
To get started using Figma Make, check out the following articles:
- Create a Figma Make file
- Attach files to a prompt in the Figma agent and Figma Make
- Edit the code of a functional prototype or web app
- Preview a functional prototype or web app
- Create and update a template in Figma Make
- Custom skills for the Figma agent and Figma Make
- Publish a functional prototype or web app to the Figma Community
- Remix a functional prototype or web app
- Publish, update, or unpublish a functional prototype or web app
- Best practices for optimizing AI credits in Figma Make
Questions about Figma Make?
If you have questions about Figma Make or how to use the product, check out the Figma Make FAQs.
