Before you start
Who can use this feature
Starter, Professional, Education (not K-12), Organization, Government, and Enterprise plans
With Figma Make, you can use the chat interface to create functional prototypes, web apps, interactive UI, and more. Figma Make is AI-driven, which makes creating your own interactive prototypes as simple as sharing some examples or having a short conversation. You can edit or improve your functional prototypes and web apps by continuing the conversation, as well as edit the preview and code directly.
Tip: To learn more about Figma Make and how you can use it, check out Explore Figma Make.
Note: Figma Make may incorporate third-party content from the internet—such as fonts, code packages, or images— into your functional prototype or web app. You are responsible for ensuring you have appropriate rights to all content before publishing.
Create a functional prototype or web app in Figma Make
To create a functional prototype, web app or interactive UI with Figma Make:
Create a Figma Make file. In the file browser, navigate to your drafts. Then, in the upper-right corner, click Make.
Tip: You can also get started by:
- In the AI chat, tell the model what you’d like to build by typing in the text field or pressing to dictate your prompt. You can do one or more of the following to guide the AI:
- Attach Figma designs.
- Bring style context from one of your Figma Design libraries. (Paid plans only)
- Add a backend to securely store and manage data and secrets.
- Use plan mode to generate a structured plan to review and refine before any code is written. (Paid plans only)
- Paste frames from Figma designs and images directly into the chat.
- Get context from external tools using MCP connectors.
- Enter your ideas and instructions in the prompt box or press to dictate your prompt.
- Search the web or fetch content from a URL to bring live, external information into your prototype.
- Click Send.
After you send your prompt, Figma Make starts generating the code for your functional prototype or web app. Depending on how complex the end result is, it may take a few minutes for Figma Make to finish generating the code. As it works, a to-do list may appear in the chat, tracking the steps Figma Make is working through in real time.
While Figma Make is working, you can continue entering prompts to add them to the queue. Queued messages can be reordered, edited, or deleted.
When the process is complete, Figma Make will respond with a summary of the changes, and an interactive preview appears.
If you encounter any issues while trying to get the initial result, see our recommendations for troubleshooting in Figma Make.
What’s next?
When Figma Make is finished generating the code of your functional prototype, web app, or interactive UI, you can:
- Edit a Figma Make file
- Copy a Figma Make preview as design layers
- Create and update a template in Figma Make
- Share the preview with others
- Publish a functional prototype or web app to the Figma Community
- Publish your functional prototype or web app
Best practices
Here are best practices for working with Figma Make, including optimizing your usage and writing great prompts, as well as best practices for working with attachments and resolving issues.
Optimizing usage
AI credits in Figma Make are consumed each time you send a prompt, and the amount varies based on factors such as the model you use, the complexity of the task, and the volume of context the the model processes to complete the task.
Learn more about optimizing for usage in Figma Make.
Prompting
Here are several best practices that are helpful to follow when working with the chat composer in Figma Make:
Be clear and direct. When you’re prompting in the AI chat, it’s best to be specific about the kind of end result that you’re looking for. When you’re specific about what you want, it gives the model fewer opportunities to make assumptions, and makes it less likely that the model will try to proactively add features you don’t intend.
✅ Prompt:
Build a note-taking app. I want to be able to:
- Name a file.
- Add and edit text.
- Format the text, such as bold, italics, and strikethrough.
- Add links to text.
- Save the file in markdown format.
⛔ Prompt:
Create an app I can take notes in.
Use examples. When you prompt in the AI chat, you should provide examples of what you want the end result to be. Attach Figma frames rather than images when you can. Frames contain structured design data, so the model doesn’t have to interpret visual information the way it does with a screenshot. Images work for general direction, but the model can’t reliably extract specific values like exact colors from them.
✅ These methods can be used individually or together in a single prompt.
Written
Add a login screen. Include common elements for login screens. For example, you should include a username field labeled “Email”, and a link to create accounts labeled “Need an account? Sign up here”.
Designs
Use the attached design as an example of the shopping cart.
- Structure your prompts with task, context, and constraints. When building a new app or feature, tell the model what you’re building and who it’s for before describing the details. Including constraints upfront, such as platform requirements or accessibility needs, helps avoid unwanted assumptions later.
- Use plan mode for complex builds. When you're starting a complex app, consider switching to plan mode before sending your first prompt. Plan mode generates a structured plan you can review and refine before any code is written. This helps ensure you and Make are aligned on the approach before building begins.
- Use the edit tool or annotations to target a specific element. Before writing a broad revision prompt, use the edit tool to select an element and adjust properties like colors, padding, margins, and text in the properties panel, or add an annotation to anchor an instruction to a specific part of the preview. This keeps the model focused on the right part of your app and reduces unnecessary regeneration.
- Don’t repeat context you’ve already provided. If you’ve attached a Make kit, added a guidelines file, or connected an MCP connector, you don’t need to restate that information in your prompt. The model already has access to it.
Don’t provide sensitive information. While Figma Make is great for creating apps and interactive UI, you shouldn’t provide things like API keys, email and street addresses, personal data, ID numbers, and similarly sensitive data in the chat composer itself. Instead, if you want an app that can do something like make API requests for you, instruct the model about the kind of secure or sensitive features you want to build. Figma Make will help you add a backend to handle data.
✅ Prompt:
I want to send requests to a private API. Add an input box where I can paste the key.
⛔ Prompt:
Use this key for the API requests: 11qYAYKxCrfVS_7TyWQHOg
Working with attachments
When you’re working with attaching images and designs to your prompt, here are some best practices to follow.
- In designs, use auto layout where possible. When you attach a design or component, the system is good at understanding the flow of content using auto layout.
- Focus on layout first and functionality after. Prompt the system towards the layout that you want, then use subsequent prompts to add functionality to that layout.
- Work in steps. Rather than trying to give the system a full, end-to-end description of the result that you want, start with a high level description of what you want. Then, as you work, continue to add more granular detail and functionality. When you’re attaching components and images of more complex designs, attach frame by frame, rather than all at once.
- Iterate on the result. For complex functional prototypes or web apps, it will likely take a few steps in the conversation to get to a result that satisfies all of the requirements you’re looking for. Don’t hesitate to tell the system where it’s gotten functionality wrong. When you do, give examples of what the preferred outcomes are.
- Common design elements and layouts yield the best one-shot results. For example, simple galleries and web apps that use a single primary frame work well, among similar design approaches. More complex or novel layouts may require additional prompting.
- Focus on desktop and full-screen friendly outcomes. We’re working to improve mobile output, but right now content that fits full-screen displays works best.
Single Attachments
When you’re working with individual attachments, here are some best practices to follow.
- Specify exact 1:1 build or reference as style. In your prompt, tell the system if you want an exact 1:1 build of the attached, or to use the attached as style inspiration/reference
- Add details for each section of the build. For the closest 1:1 build you can specify with more exactness what you want. Try doing this section by section in your design. You can also ask the model to help write a prompt that’s more detailed.
Multiple Attachments
When you’re working with multiple attachments, here are some best practices to follow.
- Build screen by screen. You can attach multiple designs or images, but for best 1:1 results try building by attaching only one or two designs at a time. Remember: the system will remember what you attached, so if it didn’t get it first time, remind it of what you attached and try again
- Style references in multiple screens. You can attach multiple designs or images to help build in the style you’d like, just remember to specify to the system you want the images used as inspiration, not 1:1 re-built
Resolving issues
When you’re trying to fix or work around issues you encounter, here are some best practices to follow.
- Clear the chat context. If the AI's outputs feel inconsistent or off-track—especially after many prompts—try clearing your chat context. This resets the AI's memory for the current file and can help get things back on track.
- Try smaller designs. If you’re design isn’t being faithfully re-created, try with a smaller attachment for a more accurate build
- Try fewer images and less content-rich designs. If you are attaching designs that have many images, svgs, or vector illustrations, sometimes the system can struggle. Try scaling back the fidelity or size of images, or use a less content-rich attachment.
