Before you start
Who can use this feature
Education (K-12), Organization, and Enterprise plans
Members only
Organizations often have internal tools and systems, with private information or data, that can't be shared outside the organization.
Private widgets allow members of the organization to use organization-specific widgets, without having to share them with the rest of the Community.
- Any member of an organization can make and share a private widget.
- Only team admins can publish widgets to the team's Community profile.
- Only organization admins can share publish widgets to the organization's Community profile.
Publish private widgets
Only organization admins can publish public widgets to an organization profile.
When publishing a widget, you can use the Publish to setting to choose whether to publish the widget to the organization or the Community. Private widgets don't need to go through the review process before they are available to use.
To create a private widget for an organization, follow the steps to publish widgets to the Figma Community. On Add the final details page, set Publish to to your organization.
Only the widget's original publisher can change the plugin's access. They can update this setting by publishing an update to the widget.
Update the Publish to setting to change who can access the widget. If you're changing a widget from private to public, it will need to go through Figma's plugin and widget review process.
If the original publisher has left the organization and you need to transfer ownership of a private widget, contact the Figma Support team.
View private widgets
To find and install widgets that are private to your organization:
- From the file browser, click All teams or All workspaces.
- Select the Widgets tab at the top of the page.
- Browse through any widgets that are private to your organization.
- Select a widget and click the ↓ Try it out button to add the widget to your account.
