Who can use this feature
The Figma Community is a space where people, teams, and organizations can publish a number of resources, including:
- Design resources, such as UI kits and wireframes
- Website templates
- Figma Make projects
- Extensions, such as plugins, widgets, and apps
- Whiteboarding templates for activities like diagramming and brainstorming
- Slide deck templates for presentations
- Weave tools for AI-powered image and vector generation
Join the Community to discover resources and support other creators.
Our vision is to make design accessible to all, and the Community is one part of that vision. Help us build an inclusive space where people from around the world can share and discover creative work.
View the Figma Community Guidelines →
Explore the Figma Community
You can find Figma Community resources by going to figma.com/community or you can access it directly from the Community page in the file browser.
Tip: Accessing Community resources from the file browser gives you more personalized recommendations based on your selected role in your account settings.
You can find resources by browsing through feature categories. You can also search for specific resources and creators by name, tags, or profile handle (for example, @learn). Enter your search term in the Search field at the top of the screen and press Enter.
You can quickly filter search results by Files and templates, Plugins, Widgets, Apps, or Creators. The count next to each option lets you know how many results there are for each resource. You can further narrow down the results using the additional filter options.
Admins on an Organization or Enterprise plan have the ability to manage access to Community resources from the file browser. If you don’t see anything within the Community page in the file browser, your admin may have turned it off.
Team and organization admins can also browse the Community as an admin. This allows you to manage resources on the team or organization's profile, as well as manage plugins across the organization. Access Community as an admin →
Community resource types
You can find the following types of resources on the Figma Community:
- Website templates
- Weave tools you can run on images and vectors in Figma Design
- Figma Weave workflow templates for AI-powered image editing and generation
- Community riffs
Note: You can now purchase resources directly from the Community. Learn more about purchasing resources.
Design resources and whiteboarding
Design resources are snapshots of Figma or FigJam files that have been published to the Community.
Explore FigJam and Figma Design files, find useful resources like kits and collections of icons, interact with prototypes, and view relevant information from the file page.
Learn more about Community files:
Figma Weave
Figma Weave is a creative platform for AI-powered media generation and editing. It's available as a standalone experience at weave.figma.com and is currently separate from Figma.
The Community hosts two kinds of Figma Weave resources: tools, which run directly in Figma Design, and workflows, which open in Figma Weave.
Weave tools
Weave tools are AI-powered apps you can run on your design content without leaving Figma Design. A tool turns a workflow built in Figma Weave into a set of inputs you can use without opening the workflow.
You can use tools built by Figma and tools published by other Community members. On Organization and Enterprise plans, you can also use tools published internally to your organization.
You publish tools from Figma Weave. Your publishing destination depends on the Figma plan connected to your Weave account:
- Starter or Professional: Publish to the Figma Community.
- Organization or Enterprise: Publish internally to your organization. You can't publish to the Figma Community.
You can also open a Community tool's underlying workflow in Figma Weave to explore how it was built, customize it, and publish your own version.
Only tools that produce images or vectors can run in Figma Design. Tools with other output types, such as video or 3D, can be published to Community but won't run on the Figma canvas.
Learn more about Weave tools:
Weave workflows
Under Figma Weave, find pre-built workflows you can use to get started quickly. When you select a Figma Weave Community file, you'll be redirected to Figma Weave where you can duplicate the file to your Figma Weave account and start exploring.
These files let you:
- Duplicate proven workflows into your workspace
- Learn how workflows are structured
- Customize them for your own creative needs
Note: You'll need a Figma Weave account to duplicate and use Weave workflows. If you already have a Figma account, you can sign in at weave.figma.com using your existing Figma credentials.
Presentations
Under Presentations, find slide deck templates contain pre-configured styles, colors, and slide layouts, and are intended to be used with Figma Slides.
Learn more about slide deck templates:
- Duplicate slide deck templates →
- Publish slide deck templates to the Community →
- Community publishing permissions →
Extensions
The Extensions section of the Figma Community contains plugins, widgets, and apps. Extensions provide various ways to interact with Figma inside and outside of the products. Plugins enhance actions and workflows inside of Figma files. Widgets enable multiplayer activities on the canvas. Apps let you interact with Figma files and content on other platforms.
Plugins
Plugins are third-party scripts or applications that extend the functionality of Figma's products. Use plugins to customize your experience or create more efficient workflows in Figma Design, Dev Mode, FigJam, and Figma Slides. Anyone with can edit access can run a plugin in a file. Plugins are only visible to the person who ran it and cannot be interacted with by other users in the same file.
Creators can choose to include a playground file when publishing a plugin. Playground files provide additional context on how and when to use the plugin.
Learn more about plugins:
Widgets
Widgets are custom objects you can add to the Figma editor or FigJam board. Use widgets to level up your collaboration sessions with different tools, data from external applications. Anyone with can edit access can add a widget to a file or interact with widgets added by other users. Unlike plugins which are only visible to individuals, widgets are objects that everyone in the file can see.
Creators can choose to include a playground file when publishing a widget. Playground files provide additional context on how and when to use the widget.
Learn more about widgets:
Apps
Apps are third-party platforms where you can interact with Figma files, such as connecting to Figma designs and components, adding Figma files as resources to documents and presentations, applying your design systems to code, and more. Apps require you to authenticate your Figma account on the platforms you're using. The exact set of permissions you grant to your account will vary based on the app and will be listed when you authenticate. Requested permissions are also visible on the Community page for the app.
Unlike other resources in the Community, Community pages for apps don't include playground files. This is because apps are for integrating with Figma on third-party platforms, rather than working inside Figma products.
Learn more about apps:
Community riffs
Get inspiration from other creators by viewing riffs in the Figma Community. Riffs are lightweight assets like frames, images and videos, illustrations, Make prototypes, and more.
Community riffs let you:
- Get inspired through a feed that refreshes daily
- Bring riffs into Figma Design or Figma Make files to build on
- Share your ideas by posting riffs to your Community profile
Resource Community pages
Once you’ve found a resource that interests you, click on the listing to view its Community page. The Community page is where you can read the resource’s description, like and save resources, view comments left by the creator or other Community members, and get the creator’s contact information for support with using the resource.
Usage metrics
When viewing a resource's Community page, you may notice two numbers next to the creator's name. The number next to the heart icon indicates how many users have liked the resource. The other number indicates how many people have used the plugin or widget, duplicated the file, or authenticated the app.
Note: On paid resources, this metric includes the total number of people who have previewed or purchased the resource.
Community profiles
Community profiles showcase contributions to the Figma community.
You can create Community profiles for individuals, teams, or organizations. Create profiles for each of your accounts or use one profile across all of your Figma accounts.
Learn more about Community profiles:
