Who can use this feature
Education (K-12), Organization, Government, and Enterprise plans
Organization admins only
Organizations give you greater control over what's shared within your business.
Privacy and security by design
Security is part of everything we do. It’s top of mind in how we work, treat customer data, and develop our product.
Figma has completed a SOC 2 Type II audit. SOC 2 is a security compliance standard for software companies in the United States. Its guidelines and policies help businesses, like Figma, protect customer data.
Learn more about Figma's Privacy and Security policies.
File and draft ownership
The organization has ownership over all the files created within the organization. This includes files within a member's drafts. When you remove a member, all their teams, files and folders will stay in the organization.
Figma will also move files in a deleted member's drafts to a shared folder in the organization. Organization admins can access these files and delete or redistribute them.
Configure share settings in a file
There are a few ways members can get access to files in an organization:
- A member invites them to the file
- They are a member of the team or folder
- They open a link to a Figma file (link sharing)
Use link sharing settings to define who can open the file, and whether they have view or edit access. This includes members of the organization and guests outside of the organization. Guests of an organization can only access files and teams to which they have been invited. Learn more about managing public link sharing and open sessions.
You can update the link sharing settings for each file. The default settings are Anyone at organization with link and can view.
Who can access the file
To open the share modal from any file, open the file and click Share in the top-right.
- Choose Anyone to allow people inside and outside the organization to access the file. This includes both members of the organization and Guests who have the link.
- Choose Organization access to allow anyone in the organization to access the file. Use this setting for library files you want to share with the whole organization. Guests of the organization won't be able to access these files unless you invite them to the file or team.
- Choose Only invited people if you only want team members or people you explicitly invite to the file to access it.
What can they do
Choose what level of access other members of the organization have, once they open the file.
- Choose can edit to give anyone who opens the file the option to edit.
- Choose can view to allow people to view the file without being able to make any edits.
To choose your organization's prototype access level, open the prototype and click Share prototype in the top right to make those changes.
It's possible to disable public link sharing in an organization. This prevents anyone outside the organization from accessing files via the file link.
Organization admins can turn link sharing off and on on the Settings tab of the organization's Admin. Learn more about organization admin.
Permissions
In an organization, every member and guest has a seat type that determines which Figma products they can access.
In a team, permissions determine how members can interact with its files and folders.
- Register official company domains for email addresses
- Invite members to your organization as members or guests. Guests can only access resources you invite them to.
- Set and update permissions at any time.
- Set different levels of organization access levels for teams.
Learn more about permissions in an organization.
Activity logs
Activity Logs provide a record of how users are interacting with files and resources. This allows you to track what's happening within your organization:
- See who is accessing, copying and sharing Files
- Track changes made to teams, folders and file permissions
- View activity for individual members
- Track changes made by organization admins
- Identify and prevent misuse of organization Resources
Learn more about activity logs.
SAML SSO
Organizations that need enhanced security requirements can configure SAML SSO.
Security Assertion Markup Language (SAML) is a security standard for logging into applications.
Single Sign On (SSO) allows users to log into many applications or websites via one set of login details.
Figma has integrations with the following providers:
You can also set up a custom SAML configuration with a provider that isn't on this list.
Two-factor authentication
Note: Figma for Government requires SAML SSO. Its authentication requirements differ from the optional Google SSO and email-and-password settings described for commercial organizations.
If you don't have SAML or Google SSO enabled, members of your organization can add extra security via two-factor authentication (2FA).
When enabled, members will need to confirm their identity every time they log in to Figma.
Members will need to set this up individually, in their account Settings. There isn't a way to enable 2FA or make it mandatory across an entire organization.
If you're using SAML SSO, you may be able to enable 2FA with your identity provider.
Learn more about two-factor authentication.
Restricted access
Admins on the Enterprise plan can restrict members from creating new Starter or Professional plans using their work email address.
Learn more about restricting external plan creation.
With the Governance+ add-on, organization admins can also restrict access to external content. This broader restriction prevents members from creating or editing content outside the organization and changes their access to existing external files to view-only.
