In Figma, you work in files, which can be organized into projects.
You can browse all your files and projects in the file browser.
Open the file browser by logging in to your account at figma.com. If you’re inside a Figma file, you can access the file browser by clicking the Figma menu > Back to files.
Projects
Projects let you group related files in one space, similar to folders in a file system. They can include files from any Figma product.
Projects are created within teams.
On the Professional, Organization, or Enterprise plan, you can create unlimited projects. On the Starter plan, you can create one project.
Browse the following resources to learn more about creating and managing projects:
- Create a new project
- Project permissions
- Move a project
- Rename files and projects
- Delete and restore projects
- Guide to connected projects: Learn how two separate teams or organizations—like an agency and a client—work together in a shared project.
Organize files into projects in whatever way works best for you. Your company’s structure may influence how you use projects. Projects don’t support subfolders, so plan your structure accordingly.
Projects FAQ
From the file browser or within a specific file, the project name is listed beneath the file name.
View all your projects in the file browser.
Open the file browser by logging in to your account at figma.com. If you’re in a specific Figma file, you can access the file browser by clicking the Figma menu > Back to files.
You can browse your content from the left sidebar.
- Starter and Professional: Go to All projects
- Organization and Enterprise: Use All teams or All workspaces (if enabled). Select a specific workspace and/or team to see a list of projects.
To invite someone to a project:
- Open the file browser by logging in to your account at figma.com.
- If you’re in a specific Figma file, you can access the file browser by clicking the Figma menu > Back to files.
- Open the project page.
- On the Starter or Professional plan, select All projects from the left sidebar. Then, select a project.
- On the Organization or Enterprise plan, select All teams from the left sidebar. Select a team, then select a project.
- On the Enterprise plan with workspaces enabled, select All workspaces from the left sidebar. Then, select a team from the Your teams tab. Select a project in that team.
- Click Share.
- Enter in the email address of the users you’d like to invite, separated by commas, and set their project permissions.
- Click Send invite.
Files
Figma supports multiple file types, including Design files, FigJam boards, Slide decks, and more. Each file type has its own set of tools and features tailored to different workflows.
- Professional, Organization, and Enterprise teams can create unlimited files and drafts
- Starter teams can create:
- 3 total Figma Design and Figma Sites files in a project
- 3 files in a project for each other Figma product (i.e., 3 Figma Slides files, 3 FigJam files, etc.)
- Unlimited drafts
Browse the following resources to learn more about creating and managing files:
- Create a new file
- File permissions
- Move a file
- Duplicate or copy files
- Save a local copy of files
- Delete and restore files
- Leave a file or prototype
- View a file's version history
- Create and manage pages
Files FAQ
Figma dynamically loads only the page you land on—often the first page. This makes even large files load quickly.
Pages load individually as you navigate
Certain actions may cause the file to load all pages. For example:
- Searching across all pages in a file.
- Selecting All pages when you review updates to components, styles, and variables.
- Running a plugin or widget that needs the whole file. While plugins are usually optimized to dynamically load pages, some plugins need to load all pages in order to run.
For a very large or complex file, it can take a few moments for Figma to load all the pages.
Each Figma product uses its own file format, which can only be opened in Figma.
You can save a copy of a file to your computer in the following file formats:
- Figma Design:
.fig - FigJam:
.jam - Figma Slides:
.deck - Figma Buzz:
.buzz - Figma Sites:
.site - Figma Make:
.make
Saving local file copies is useful if you want to back up your files if you go offline unexpectedly, or if you want to move files between Figma accounts.
Every Figma file has a unique URL. The URL includes several components that tell you information about the file.
Consider the following URL:
https://www.figma.com/design/abttA1F3GxZdZlkI9t5s99/Example-Figma-file?node-id=32-9
designindicates that the file is a Figma Design file. Other options include:-
protofor Figma Design prototypes -
boardfor FigJam files -
slidesfor Figma Slides files -
deckfor Figma Slides files in presentation view -
sitefor Figma Sites files -
buzzfor Figma Buzz files -
makefor Figma Make files
abttA1F3GxZdZlkI9t5s99is the unique file key. Knowing how to find your file key is useful if you’re embedding files in an app or using the Figma REST API. -
Example-Figma-fileis the name of the file. -
32-9is the unique ID of a selected layer in the file. When you use a URL that includes the node ID of a layer, the file opens focused on that layer.
Note: The file name doesn't impact the functionality of the URL. If the file name changes— if "Example Figma file" changes to "Old Figma file" for example—previous versions of the URL that include the old name continue to work.
Drafts are a personal space for creating and experimenting with Figma files before sharing them with a team or moving them to a more permanent location like a team project.
You can view your Draft files for each team from the left sidebar of the file browser.
Drafts are private to you, and only people that you specifically invite to your files will have access to any files in this space.
Drafts on the Starter plan do not support collaboration with other editors, although they can be shared with unlimited viewers.
When you’re ready to share a draft, you can move it to a project.
