Who can use this feature
Professional, Education, Organization, and Enterprise plans
Figma Buzz was released in open beta at Config 2025. It is currently available on all seat types. Learn more about what’s included in the beta.
Use Figma Buzz's template guidelines to create brand-controlled assets that your team can use confidently. By strategically locking brand elements and publishing templates, you can maintain visual consistency while empowering your marketing team to create assets independently.
You can also use approvals alongside templates to review and confirm assets before they’re exported—helping ensure final outputs meet brand and quality standards.
How brand controls work in Figma Buzz
Brand controls in Figma Buzz work through template guidelines—restrictions you set on specific design elements to maintain brand consistency. When you lock objects in a template, users can only edit the elements you've designated as changeable.
Templates with guidelines appear with:
- Pink outline around the asset
- Lock icon next to the asset name
- Limited editing options in the Edit content panel
Template users can:
- Update unlocked text fields and images
- Edit content through the Edit content panel
- Remove guidelines if they need full editing access
- Swap variants of any components
Tip: Template guidelines serve as guardrails, not roadblocks. They should guide users toward brand-compliant choices while still allowing the flexibility needed to create effective materials.
1. Design your brand-controlled template
Start by creating an asset that balances brand consistency with user flexibility.
Plan your locking strategy
Before you start locking elements, consider what your team needs to edit versus what should remain consistent. The position of each layer on the asset is locked by default, so you only need to lock text and image layers that you don’t want to be edited.
For example, you likely want to lock things such as brand logos. However, you can leave body text, descriptions, images, and call-to-action text as unlocked.
Create your template asset
- Start with a new Figma Buzz file.
- Design your asset using Figma Buzz's creation tools or paste designs from Figma Design.
- Name text layers descriptively to help users understand their purpose (e.g., "Event Title" instead of "Text Layer 1"). Renaming layers in design mode requires a Full seat and edit access to the file.
- Select an asset.
- Toggle design mode to use Figma Design tools in Buzz.
- From the Layers panel on the bottom left, edit layer names.
Tip: Test your asset with realistic content to ensure your design accommodates different text lengths and image types.
2: Lock brand elements
Apply template guidelines by locking the elements that should remain consistent across all uses of your template.
Lock objects to maintain brand standards
- Select the object you want to lock (logo, background, etc.).
- From the toolbar, click More.
- Click Lock.
Repeat this process for each element you want to protect from editing.
Test your brand controls
Before publishing, verify that your locking strategy works as intended:
- Select your asset and click Edit content.
- Review which fields appear in the editing panel—these are the elements users will be able to change.
- Try editing different elements to ensure locked items can't be modified.
3: Publish your brand-controlled template
Note: Professional teams can create five team templates. You cannot publish a template file from your drafts. Before you publish, move the file from your drafts folder to a folder.
Make your template available to your team by publishing it to your organization.
- Click Share in your template file.
- Select Publish template
- Enter your template details:
- Clear, descriptive name
- Helpful description with usage guidelines
- Representative thumbnail image
- Click Publish.
Your template will now appear in the "From your team" section of the template picker for all team members.
Learn more about creating and publishing templates.
4: Guide your team in using brand-controlled templates
Help your team understand how to work with your brand-controlled templates effectively.
- Share the following Figma Learn resources on using Figma Buzz as a template consumer:
- You can also consider creating your own usage documentation that explains:
- Which templates to use for different purposes
- What content can and cannot be changed
- Brand guidelines for images, messaging, and tone
- Who to contact for template questions or requests
Best practices for effective brand controls
Balance control with flexibility
- Lock strategically: Focus on elements that are critical to brand consistency
- Test with real content: Ensure templates work with actual marketing content, not just placeholder text
Tip: Consider using auto layout when creating the asset to help ensure designs will respond dynamically to content changes.
Create comprehensive template sets
- Think in campaigns: Create related templates that work together (Instagram post + story + Facebook post)
- Consider all formats: Provide templates for different platforms and use cases your team needs
- Plan for variations: Create templates for different campaign types, seasons, or product categories
By setting up thoughtful brand controls in Figma Buzz, you can ensure your team creates consistent, professional assets while reducing the design review burden and empowering teams to work more independently.
Incorporate approvals into your workflow
Use approvals to add an extra layer of quality control when needed—especially for high-visibility or brand-sensitive assets.
- Require approvals for critical assets: Consider requiring approval before export for campaigns, paid media, or externally facing content
- Align on reviewers: Define who is responsible for approving assets (for example, brand, legal, or marketing leads)
Learn more about approvals in Figma Buzz.
More resources
Review the following blog article for some more tips on building branded templates in Figma Buzz:
