Before you start
Who can use this feature
Available on all plans
Teams are dedicated spaces within an organization for organizing and collaborating on files.
Organization and Enterprise plans support an unlimited number of teams. These plans have permission settings that impact how others in the organization can access and manage teams.
Starter and Professional plans each include a single team, which are managed by admins on those plans.
Team permissions
Team permissions define what actions someone can take at the team level—like creating folders, inviting members, or changing team settings.
Select your plan to see how team permissions work.
Starter and Professional plans each consist of a single team. The actions individuals can take depends on their role: full members, limited access members, and admins.
The table below outlines which team actions are available for users on the Starter and Professional plans.
| Action | Full member | Limited access member | Admin |
| Invite others to the team | (can only invite others to join with a View seat) | ||
| Create folders |
Limited access members
cannot create top level folders. They can create nested folders if they have edit access to the parent folder. |
| Delete team files * | |||
| Delete top-level folders * | |||
| Delete nested folders * | |||
| Update team names or descriptions | |||
| Remove members from the team | |||
| Change the team name, icon, or description | |||
| Manage Community profile for team | |||
| Choose default libraries for the team | |||
| Delete team |
*Note: To delete a file or folder, you need edit access to the resource itself and edit access to the folder or team it lives in — either through a direct invite or inherited permissions.
- For files and nested folders, that means having an editor role on the containing folder.
- For top-level folders, that means being a full member of the team.
On the Organization and Enterprise plans, any member of a team is given
can view or can edit permissions on that team.
In addition to can view and can edit permissions,
a
team member can be an owner or an admin:
- Admin: Admins have extra administrative rights within the team. They can manage any team settings, including shared libraries.
- Owner: Every team, folder, or file has an owner. There is only one owner per team. The owner is the person that created the team, but ownership can also be transferred.
The table below outlines which team actions are available for each permission level:
| Action | Can view | Can edit | Team admin/Owner |
| Invite others to the team | With can view permissions only | ||
| Create folders | |||
| Move files and folders | |||
| Delete team files or folders | |||
| Update collaborator permissions on the team | |||
| Transfer ownership of the team | Only the team owner can transfer ownership | ||
| Delete team | |||
| Upload and manage team fonts (Organization and Enterprise plans only) |
Manage team permissions on the Organization and Enterprise plans
On the Organization and Enterprise plans, you can share teams with other users in your organization, and manage what actions others in your organization can make on that team.
Team permissions are managed through the team's share modal. To open the team share modal:
- Open the file browser by logging in at figma.com. If you're in a Figma file, click the Figma menu > Back to files.
- Navigate to the team:
- On the Organization or Enterprise plan without workspaces enabled, select All teams from the left sidebar, then select a team.
- On the Enterprise plan with workspaces enabled, select All workspaces from the left sidebar, then select a team from the Your teams tab.
- Click Share.
The share modal shows everyone who can access the team, organized from broadest to most specific:
- Organization or workspace access: who can access the team across your organization or workspace
- User groups and individuals: people who have been directly invited to the team and their permission levels
Click any row to adjust permissions for that group or individual
Set organization or workspace access to a team
When you create a team, you’ll choose how others in your organization can access it via the Who can access dropdown.
To set broader access on a team:
- Open the team share modal.
- From the Who has access dropdown, select the top row to determine who can access the folder:
Only those invited: Only people you explicitly invite can access the team. Then, control if people in your organization who haven’t been invited can discover the file by setting team visibility:
- Visible: Members can discover and request access in the file browser.
- Hidden: The team cannot be found by search. Members must be invited by an existing member.
- [Workspace name] (Enterprise plan only): Allows workspaces members to access the team via link or through the file browser.
- [Organization name]: Select your organization name to allow members to access the team via link or through the file browser.
- If organization or workspace access is allowed, choose a permission level under What they can do:
- View: Organization or workspace members can view and comment on files in this team.
- Edit: Organization or workspace members can create/edit files, add members, and manage team permissions.
- Click Save.
Set team access for user groups and individuals
On Organization and Enterprise plans, you can invite user groups to a team directly from the share modal. Everyone in the group gets the same can edit or can view permission, and access updates automatically when someone joins or leaves the group.
Learn more about creating and managing user groups.
You can also invite individuals to a team and assign them can edit or can view permissions directly from the share modal.
To change a user’s team permissions:
- Use the dropdown next to each user to update their team permissions. Click Remove to remove a member from the team.
Inherited permissions from team to folder
By default, a member's access to folders and files in a team is inherited from their team permissions.
Example
Fruit Folder is a folder within the Produce team.
- John has
can editteam permissions on the Produce team and is givencan editaccess to Fruit Folder by default. - Jeanie has
can viewteam permissions on the Produce team. She is givencan viewaccess to Fruit Folder by default.
You can override someone's inherited permissions by editing their permissions on that file or folder. Learn more about file and folder permissions.
Example
James has can view permissions on the Produce team. His manager, Vanessa, invites him to a specific file within that team with can edit access.
With explicit edit access to the file, James is able to make edits to that file. He only has can view access to other files and folders in that team.
Team permission FAQs
Seats are separate from permissions.
In Figma, a person's seat determines which Figma products they have access to. For example, a user with a Collab seat has access to FigJam and Figma Slides.
Permissions determine which files, folders, and teams they can edit.
For a user to be able to edit a file, they need both the appropriate seat and permissions.
No, team permissions do not impact your subscription or bill. Your bill is determined by your plan and the number of paid seats you purchase.
