Who can use this feature
This guide is for customers on the Organization and Enterprise plans
Organization admins only
Organization admins have an extra item in their file browser sidebar called Admin. This is where you can manage high-level settings for your Figma organization, including:
- Access
- Members and guests
- Teams
- Resources like fonts, plugins, and libraries
- Workspaces (Enterprise plan only)
- Billing groups (Enterprise plan only)
- Additional security and privacy controls
- Billing
Manage access to the organization
Claiming domains
Domain capture lets you automatically add people with a company email address—like @example.com—to your Figma organization.. This helps admins keep all users at the company within a single Figma organization.
Login and authentication
You can enable single sign-on (SSO) with an identity provider (IdP), and choose how users authenticate themselves.
Provisioning with SCIM
Figma supports SCIM provisioning, making it easier to manage large teams or changes in team membership. With SCIM, you can synchronize user data, such as names and emails, between your IdP and Figma. On the Enterprise plan, you can also set seat types using SCIM, which gives admins more control over cost changes between billing cycles.
*Only available on the Enterprise plan
Manage members and guests
The People tab is where you can view activity, manage access, and review paid licenses for every member and guest in your organization.
- View members and guests
- Manage seats in an organization
- Set approval settings for new seats
- Manage drafts of deleted members
- Remove people from an organization
- Make someone an organization admin
- Add or remove workspace admins
Manage guest-specific controls
- Invite guests to organization resources
- View guest access
- Restrict or prevent guest access*
- Accept guest access requests*
Tip: Use the Activity log to review how people in the organization interact with files and resources.
Manage teams
Organization admins can manage all open and visible teams, as well as any hidden teams they have been invited to.
Manage resources
Resources like plugins, widgets, libraries, and fonts help streamline design and collaboration. You can also manage publishing for products like Figma Sites and Figma Make, and whether backend integration is implemented. You can control how these resources are used to match your company’s security and privacy requirements.
Plugins and widgets
Plugins and widgets are third-party scripts or applications that extend the functionality of Figma Design and FigJam.
- Create private organization plugins
- Manage plugins and widgets in an organization
- Save plugins for the organization
Libraries
As an organization scales, it can have tens, hundreds, or even thousands of published libraries available. Figma has several different ways organization and workspace admins can help people surface and use the best libraries for their work:
Tip: Every member of an organization, including organization admins, can view library analytics to understand how libraries are used across the organization.
Fonts
Figma organizations can upload and share custom fonts to specific teams or across the organization. This removes the need to share, install, or update fonts for individual users. It also allows people using Chromebooks and Linux to access custom fonts.
Publishing
Figma Sites and Figma Make provide a way to publish sites, functional prototypes, and web apps to the public web. When published, individuals outside your organization can discover and interact with the published resources. You can control whether it's possible for these resources to be published to the public web. On the Enterprise plan, you can also require passwords on published sites and apps.
Backend integration
When working with Figma Make, your users can integrate a backend in their files. The backend allows the functional prototypes and web apps created with Figma Make to do things like maintain an app's state across browsers, provide authentication flows, and store secrets, API keys, and tokens that are needed to make requests to different servers. You can manage whether Figma Make files are able to be integrated with a backend.
Connecting to external data sources in Figma Make
By default, members of your organization can connect to external data sources via the Model Context Protocol (MCP) in Figma Make. As an organization admin, you can disable these connectors to control data access while keeping Make-powered workflows available.
Manage workspaces
Workspaces are collections of teams, people, and resources within a Figma organization. They help companies with many business units, sub-brands, or design systems add structure to their Figma organization. Workspaces are only available on the Enterprise plan and are managed by workspace admins.
Manage billing groups
Billing groups let you sort people in your organization according to internal budget sources. Each billing group has billing group admins who manage free and paid seats in the group. Billing groups are only available on the Enterprise plan.
The security and privacy of your organization is extremely important to us. Figma has different controls for keeping your data secure:
- Restrict access to content from outside your organization*
- Require link expiration on design files*
- Require password protection on files*
- Disable open sessions in FigJam
- Disable public links
- Enable or disable audio for organization
- Disable cursor chat
Manage billing
Figma has multiple products: Figma Design, FigJam, Dev Mode, and Figma Slides.
You assign a single seat for each user on your plan, and the seat type determines which products they have access to. Keep in mind that when you change someone’s seat type, you might also be changing their billing status.
